Arkansas members
Happy easter! Lol what's a good brand for headers? Nothing ebay....
Bit of a long shot here but I am currently in Arkansas and my friends output shaft just bit the dust. Fairly sure the splines shredded in the transfer case. I have sourced a new one in Clarksville TN but I'm likely going to be needing a transfer case as well as I can assume the teeth in the transfer case input are shot to shit. Does anyone here happen to have a 2g automatic awd transmission and/or a 91-96 Transfer case in good condition they can let go of cheap? Been up for 24 hours after working land all day yesterday, covered in gear oil and at, minimal tools, and basically stuck here until I find the parts we need.
Any help would be appreciated.
Bud where are you located. I don't have the parts but you can come to the garage and we can work on it.
The stock ported one works great, but id get a FP if anything.
Anyone have a complete 6 bolt block for sale? Needs to be running condition to swap with my 7 bolt. :|
Curious cause mine is cracked so good time to upgrade LOL. Also switching to a different o2 housing for an external wastegate for when I upgrade my turbo. Slowly going up xD
I did pretty good with the stock 2g ported and an e316g internally gated.
What turbo are you going with? I was running 29+psi on the 16g with the internal gate. With little boost creep and held like a rock. This was with a 3" o2 housing and 3" downpipe. Fun little setup that was. I'd always recommend going external off the manifold rather than turbo.
I wonder if having a 86mm gasket caused the problem. Wouldn't there be a lip exposed to cylinder combustion?
Today I decided to go visit the family and just had to leave a mark when leaving sideswiped my moms Denali put a dent in my door and took my passanger mirror off barley scratched the truck
Holy crap that sucks LOL.
But on the other hand, I do have a black mirror if you need one. :thumb:
From what I heard the big 16Gs didn't like more than 25 psi? I'm not sure which turbo yet, just wanted tubular headers, O2 housing for an external wastegate and run my full 3" exhaust. Might switch to a straight pipe instead of a catback though. Also needing to change out my flywheel...was in a rush when I changed my clutch and it was glazed. But even this clutch I didn't plan to have long LOL
Anything above 27 psi starts to get out of the efficiency range of the turbo. Doesn't mean it won't make more power after that tho. ;)
Anyone got a 6bolt long block?
I got a 7bolt split thrust and 6bolt block for sale if you are interested.
Got the car fixed for the time being. You won't believe how incredibly easy it is to get to the center diff on an Auto AWD trains. Just welded it until I can locate a 2g output shaft.
Anywho, anyone need a good laptop, core i5, for around $225? Need to sell it immediately.
I do need a laptop, just for tuning though. I just don't want to spend over $100 on something I'm using just for tuning.
Adjusting the launch limit speed from 12 to 2 helped a lot! Thanks for the advice!
Not a whole lot you can pick up for $100, save for craigslist deals on old Pentiums. >.< I'll cut ya' a deal and do $175 if you want it~ It's about a $600 laptop.
GReddy
Need oil pressure gauge bulb for my greddy oil pressure gauge. This seem to be the right part?
Them seem to be out of stock. I need a bulb for my gauge, part number for Greddy is 16400061. I found one on ebay, but for $11 it's not happening.
