- Thread starter
- #26
98talonblack
- 124
- 2
- Dec 22, 2011
edinburg,
Pennsylvania
What are you going to use to tune with?
Im so so so behind. I've been down for a little over a month and finally installing the 16g. Hope to meet you real soon
FYI if you don't want too swap those 2gb talon bumpers for 2gb eclipse bumpers let me know
Good luck with the build! Think our cars always pick the best time to mess up, its usually after it gets attention and an upgrade. My Supra did that, turbo went out the very day I got it running right and getting into boost .
Being perfectly honest you really dont need to spend that much for 300hp... Its a relatively conservative goal and doesnt take the biggest and the best of parts ya know Good job on the evo pump, as long as youre planning on sticking with that goal and not building for higher later on then thats all you'd need so you can skip the 255/AFPR. I made 333/325 whp on pump, and thats a very tired 215k mile 6 bolt, so 7.8 compression not 8.5. Youll get there. Any questions just ask, Ill subcribe and contribute where I can
Ok big update im sending the ol black box ecu out to a fellow dsmer and hes gonna tune it for me and give me 2 step and antilag control as well finally the tuning question has been answered!
It is SUPER easy to do this to a black box ECU. If you get the Tactrix cable, all you do is plug it in and flash the ECU with CeddyMods. It sounds hard, but trust me if I can do it so can you.
