mondale
- 66
- 2
- Dec 1, 2010
Minneapolis,
Minnesota
I am looking for a source for the stock type rear subframe bushings. Not the mustache bar bushings, but the big ones that tuners nation and boostedx sold poly replacements for. The issue that I am having is that my outer ring of my stock bushing is badly rusted, and this ring must be present for a proper fit of the machined aluminum bushings that I have purchased from Bulfab found here:
Bulfab, LLC. Custom Fabrication - Subframe Bushings
I do not think that the bushings will fit properly as they are a very tight fit by design. I would be willing to buy 2 new OEM or OEM type (napa or etc which I have tried already) bushings and destroy them to get this outer ring that I need. Does anyone know where I can get these new? Mitsu says no, as well as all the store front parts stores that are nationwide. I am running out of ideas besides returning these ones and getting a custom set machined that will fit without the outer bushing ring in the subframe. Thank you for looking!
