flopp
- 50
- 0
- Jan 24, 2014
NAVARRE,
Ohio
ok so I installed a new slave cylinder new clutch fork and ball new clutch new throw out and checked that the clutch for was in the middle/ slightly toward the drivers side of the car and blead the crap out of it all. The slave cylinder is pushing the fork all the way to the edge of the transmission and the clutch fingers are going flat but the clutch will not disengage. when it is sitting back on the ground it will not go into gear at all I can not figure out is going on with this thing. I searched on here but the problem is i am making out the clutch fork travel so it really cant be a maladjusted pedal or the slave cylinder needing to be longer though we did try that. heck it cant even be the assembly needs welded because as stated it is pushing the fork completely over. I really don't want to pull this trans out again but is it possible that even my brand new fork and ball needed shimmed? If so maybe i can get a line wrench on the ball through the fork boot and loosen it up and then place c shaped shims in there to space it out ???? Help I am really stumped and need to get this out of the garage i have other cars to work on
