CountryDSM
- 177
- 22
- Dec 13, 2012
Chandler,
Arizona
Local Ad I found.
Evo III Big 16g from Extreme PSI.
- He says it was purchased in 2011, says the turbo has 10,000 miles. Personally inspected and no shaft play whatsoever. Now it is a Journal Bearing turbo so If I grab it and force it around I'm assuming it will push the oil away and thats why it would move slightly.
FP Manifold
- Straight up, no ceramic coating, and nice and rusty! I most likely am going to modify my stock heat shield to work with it.
Tial F38 Wastegate 15psi spring with Recirculated O2 Housing (Seems like it's a mild steel but it has rust, usually never see these.)
All for $800 buckaroos. He doesn't want to budge and I doubt he will.
What do you think? Would you buy it. (FYI my current 16g went out, stock manifold, dumped o2 housing / internal wastegate )
This setup will benefit my build. Is the pricing fair? He isn't desperate so It's not a steal deal for sure.
FP Manifold
