TimF
- 823
- 5
- Mar 14, 2011
Aurora,
Illinois
Ok I am stuck at yet another point. I live inner city with no driveway, and my garage is constantly occupied so my neighbor let me park her car in her gravel lot to while I work on it. I am taking the engine out in pieces, due to not having garage and a engine hoist (nor the room to use one) My plan was to slide the trans over and lift the block out then pull the trans out. The trans is separated, but not enough that I can lift the motor out. I spent all morning before work twisting, jacking up and lowering, taking off parts for clearance, but the trans wont slide back enough to clear the block. I seen plenty of youtube videos and it seems no one else had problems sliding the trans over for clutch changes ect. My passenger side axle is still in the trans, I cant get it to pop out. Its disconnected from the hub so I figured I could pull the trans with it on, but my neighbor sold the house and I need the car moved by next Friday. So its either I get the engine out, or reconnect everything to move the car, and I really dont want to back track
