98PaprikaAWD
- 40
- 0
- Apr 15, 2009
Milwaukee,
Wisconsin
oh my, that carpet is to die for
Seriously, is that cut 801- Black ? and this mass backing is that the "foam" under the original carpet ? or what does it look like?
i plan to fill the car with "peel n seal" to reduce noise, i have a noisy engine, and road noise. would you still recommend mass backing or not needed ??
I put "Stinger Roadkill" down first. I like it better than brand name "Dynomat". It's a Little bit thicker than dynomat brand and also a little cheaper in price.
The black foam I think you are referring to is "Stinger Roadkill Carpet Pad". It's really dense, thick foam for extra sound deadening. [ame]http://www.amazon.com/Stinger-RKCP12-RoadKill-Discontinued-Manufacturer/dp/B001TH8OC4[/ame]
The carpet backside has the "backing" Again, here I went thicker to have as much protection from roadnoise as possible. I probably went overboard, but road noise is one of my biggest pet-peaves in this world!
