tkr
- 0
- Sep 20, 2013
Bountiful,
Utah
Is there anyway to run a front mount and keep the A/C? I'm moving to Arizona later this year and I'm afraid it will be to hot.
Ducting is key. You want the air to pass through the fmic, ac condenser and the radiator. You can use some aluminum or rubber to direct air through everything.
http://www.dsmtuners.com/forums/turbo-system-tech/409483-duct-not-duct-fmic-pix-3.html#post152670603
http://www.dsmtuners.com/forums/turbo-system-tech/409483-duct-not-duct-fmic-pix.html#post152664635
Alright that makes sense. Would the PR FMIC kit work with a/c? The only thing holding me back from front mounting it is the A/C.
I run PR's FMIC, and I don't have any issue's. average temps are roughly 186-193 at the very highest on a super hot day.
As said, proper ducting, shielding, and maintaining your cooling system will keep your temps in check.
I have the PR fmic kit and a/c still with no ducting. Never overheated and stayed around 200 degrees cruising with the a/c on, even on 95 degree days last summer. I do have an aluminum radiator tho
