NDgsx
DSM Wiseman
- 1,163
- 3
- Jun 10, 2002
Vancouver,
Washington
We have been taking care of Willy's GVR4 for quite awhile. It has been a stock 6 bolt for a long time, happy and content on 92 and a stock motor. However recently Willy got the power bug and decided to have us build him something that was capable of pushing the FP Black safely to 500whp. While it is certainly possible to do that on a stock motor, Willy didnt want to risk it so we put together a 2.0L shortblock and reused his cylinder head.
Build -
EnglishRacing 2.0L
Wiseco 1400HD 9:1 pistons
K1 H beam rods
Magnus V3 intake manifold
ACL bearings
Mild port work to the head
Crower 414 camshaft set
Crower valvesprings
Fuel Injector Clinic 1120cc injectors
EnglishRacing 3" exhaust
EnglishRacing 2" O2 dump
EnglishRacing Double pumper Fuel kit (dual intank 255s)
ETS 3.5" FMIC kit
ECMLink V3 with SD tune
Omnipower 4 bar
All of this did rather well on the break in tune, but right as it was starting to get interesting I ran out of fuel. The next stage will be larger injectors to push a little harder but until then, Willy is going to have to settle with this -
Initially there was a little bit of an oversight in this build and it was put back together with a stock 2g O2 housing though it had been ported. No matter how much you cut out of one, they simply cant flow enough before they become a restriction. How much? How about 50whp.
Before someone say its because there is more boost, which is obvious, its because the reduction in backpressure allows more boost out of the top since the backpressure ratio isnt out of control now. Turning the boost up higher before actually reduced power as the O2 housing only choked it worse with a higher spike. Once Willy gets the bug for more power I am sure we'll be turning this up even further.
Nick
Build -
EnglishRacing 2.0L
K1 H beam rods
ACL bearings
Crower valvesprings
ETS 3.5" FMIC kit
Omnipower 4 bar
Nick
