noid
- 103
- 0
- Oct 10, 2007
Burlington,
New_Jersey
I know probably a dumb question and if it would work other would have already done it and I couldn't find anything in search
Would a smaller more restrictive air filter and adapter (eBay round adapter) help with boost creep?
I have a K&N air filter with the oval adapter. I have a small 16g running off wastegate pressure that I want to run around 10psi that is creeping to around 16psi which is when it hits fuel cut. Stock fuel system. Don't want to buy anything to tune with or go external wastegate if I don't have to. I'm going to try porting a little first but was just wondering if this was worth a try. Thank you for any advice!!
