805LegendDSM
- 84
- 1
- Apr 14, 2011
Oxnard,
California
96 GST automatic, completely stock , stock internals stock Blow off valve too(2g)...only thing changed is the FPR bypassed directly t the intake manifold to a vacuum source.
Is the 2g BOV notorious I leak under boost?
My car recently after reinstalling the Starter after the solenoid in the starter mysteriously unbolted off the housing has been running a bit rich, in act it's running really rich...
Before the whole starter thing, my GST would only kill gas obviously when I'll gun in under boost and let off just so I an hear the BOV(sounds childish but even my wife can't help herself) ...
I don't really beat the crap out of the engine I just hold down the pedal to build boost and let off to hear the bov, and I noticed my gas miliage going down..
Which I believe should be normal right?
But now after the whole installment of the starter my car is running really rich killing gas like I kill tacos. Just a few minutes ago I realized even when I'm cruising not under boost and just lightly let off the gas pedal I hear the BOV slowly go off like a long whoosh until I fully let off the gas or I begin to accelerate. But from the looks of it, the BOV is leaking bad I guess? Sounds good and works fine I'm guessing here.
Another idea I had was, that since I reinstalled the starter I had literally shove it down the engine bay pass some fuel lines that I had to forcefully had to pull back. I may have pinche or ripped one? There's two fuel hoses down there I believe ? In the inside of my car is starting to smell like gas, and my exhaust fumes as well. No Leak in the injectors seals!
