all_motor_mike
- 360
- 2
- Aug 10, 2007
Peoria,
Arizona
Absolutely amazing port work and welds man. Keep up the good work.
Thank u sir
Mike
Cool thanks for the advice compression. would welding each joint slowly with lots of cool down time alleviate that issue ?
I want a dynasty do you have pulse square wave, AC balance and post/pre flow control?
That looks cool, Want to share some dimensions when your done? I want to cut it on the cnc.
You've just been jacked. Useing that shit
Wheres it gettin mounted? Was this copied off the oem? Or did you jabe plans to fit it in some cool place
Me too! How are you cutting? Or do you have a sheer? I have a short route fmic so stock location doesnt work unless thing is short
The two "front" faces were cut via vertical band saw, the rest were sheared. I have an ETS short route as well with no fitment issues.
Thanks!
I really wish aluminum was magnetic for times like this and tacking it up
Cnc cutting this weekend. Hit me up if you want anything.
Those beads look to far apart. When your do a leak test its more prone to leak. You need close beads to ensure a better seal. But other then that its not bad. !
Those beads look to far apart. When your do a leak test its more prone to leak. You need close beads to ensure a better seal. But other then that its not bad. Also seems like its welded on 1 side rather then the corner but Maybe im not seeing it right!
