96_gsx
- 0
- Oct 13, 2013
Fargo,
North_Dakota
Ok I just did my first head gasket replacement so I don't think that a sensor or ignition coil is bad. But I have spark on only the 1 and 4. So after doing some research it seems like the cam angle sensor as far as my problem. I know I'm new to this so give me a break. But is it possible that I mounted the cam angle sensor on like is there a certain angle it has to be at? Second is the only way you can get to it is to remove the intake sprocket?
