miguelmcv
Supporting Member
- 2,717
- 255
- May 3, 2009
Fresno,
California
Hi all, I just want to share my quick disconnect harness (in progress ).
I have 2 extra harness laying around for parts and decide to do a quick disconnect.
This is not a brand new harness with new wiring and new connectors etc., It's just a used harness mod it to be a quick disconnect, so I just cut wires that are bad and replace them with good wires from the same harness.
Currently, I have a wire tack in my car but is routed to the stock outlet (behind the battery) and is not a quick disconnect, that's without saying that I am running speed density now, so I don't need some connectors and I have added some other once for the fuel and IAT sensor, so I thought why not to do a quick disconnect while doing the swap and update everything.
Well, I started this a couple of days ago and the engine side is almost don, I still have to do the inside and get that famous connector to get it don,
The quick disconnect will be placed on the firewall, on one side where the shift cables comes from (towards to the driver side), the Injector resistor, Transistor and capacitor (Noise Condenser) will be installed inside the car.
Here are some pics of the progress, hope you enjoy it.
EDIT
Sorry guys, I couldn't upload any pics, there was an error everytime I try.
I will post some pics once the system let me upload them.
I got it.
Pics where to big, that's why I was having problems to upload them, I resized them and it solves the problem.
EDIT
I got it.
