What brand/weight oil are you running?
TheFallenTSI97
80
Mar 23, 2013
Huntsville, Alabama
This has probably been covered to death but I'm apparently and idiot when it comes to using the search. I tried several different key words and search options but couldn't find the information I'm looking for. So please don't kill me :confused:
I'm mainly asking the people that are pushing 500+whp on their car with large frame turbo, forged internals, and worked heads. I want to know what brand/viscosity oil you guys are using on your builds. I had been using Royal Purple on the previous setup. But with the new setup I want to ensure prolonged life of my turbo and engine. I considered running Rotella synthetic 5w-40 as it's made to support the high PSI and high temps of a turbo diesel. But at the same time I wasn't sure if that would be a little too "thick" for my car. Any input is greatly appreciated. If there is a thread on this exact topic please link me. I apologize again if I'm ressurecting a dead horse to beat it again.
I run Rotella T 15w40. Like what FP said, if you change the motor you change the nature of the motor. With a thicker oil you reduce friction. I live up in Minnesota so I gotta warm her up before I take off. :cool: I chose Rotella T cause my guy Mark runs it and it's cheap :D
Valvoline VR1 full synthetic 20w50. whatever oil you choose, make sure the Zink content (PPM 'or' parts per million) is high. the more zink, the more bearing wear resistant.
Bradd penn is good stuff but hard to find. Oriley auto parts has the VR1 in my area; goes on sale every now and again for $5 a quart! needless to say i buy out there entire stock ;)
if you want to get really serious, build you engine around the oil you will be running. you can gap your bearings and clearance whatever gaps around how think the oil will be. yupp, boost on!
I run Rotella 15-40 in all my Mitsu's. It was 0* when I left for work this morning, and my car started right up. It's not too thick at all.
Yeah, I've ran 20w50 in sub-freezing temps and never had starting issues. At that time I also had an old Walmart battery...
Around when I switched to E85 and 15w40, I also installed a Miata AGM battery with a whopping 300 CCA's (about 1/2 the suggested amperage) and still never had any starting issues as a result of cold oil.
I actually work at O'reilly so I can get them cheaper without the sale price and can just order how much I need. But we do keep some in stock I'll have to see how much and if we have just conventional and all that jazz.
I wasn't concerned about oil that could be used with E-85 when I was doing my reseach, because I had no intentions of running it, so if I came across some threads I don't remember them. Now that I'm running E-85, I have to ask what oil are you guys running with E-85? I haven't had any issues running the 10w-40 Brad Penn tho. Rotella????
I run/have run Rotella T6 Synthetic in every forced induction vehicle I've owned. 1997 Tsi, 1998 Tsi, 2006 Cobalt SS/SC, 2004 Subaru WRX. Worked good for me in all applications.
I also run Rotella T in my DD 2001 Rodeo.
Joel
Joel
See that's what I was originally thinking. I know if it can handle 60+PSI of a semi or turbo diesel it can more than handle what I'm going to through at it.
But I would only use the T6 synthetic. The guy I work with had a stock Talon FWD and used Rotella and had it start to gum up his turbo when he went to rebuild it.
Vr1 20w-50 states right on the bottle, formulated to be compatible with alcohol fuels.
E85 is fine with Bradd Penn i have ran multiple evos and dsm with E85 and bradd penn no issues
oil1.MOV - YouTube
Diesel oils generally have better detergents in them as well. Here is the valve cover off my talon 30 seconds after pulling it off. Not sure what previous owner ran but I've put through some Rotella T6. My old Cobalts head/cover looked identical after 50K using it. Zero oil deposits/baked on crap. Head is as clean.
Joel
