Boosted DSM 32
- 681
- 2
- Aug 21, 2011
McDonald,
Ohio
Hey guys. I have an hx35 8 blade on my car. Stock 6 bolt block stock head (no cams or springs) and I keep having a problem of seeing knock anything after 25 psi on my turbo and the most timing we could get out of it is 3* peak timing. I have a 4"C xs power intercooler which I believe may be causing an issue with some knock but I still think the car should be able to see close to 30 psi on pump gas especially with only 3* timing! Could it be that my motor is worn out? When we tore it apart last winter it looked brand new.
My afrs are right around 11.8 wot car doesn't break up or anything I tried it at 27 psi at the track once and was seeing 6-7* of lnock the entire time down the track (Yikes!) my Dsmlink is saying I'm flowing 44 lb/min at 7000 rpm the car runs good but I'm not happy with the power. I know a good set of cams and springs would probably give me another 40whp if not more.. I was thinking of going up to an hx40 to give me more power at the same psi but I'm going to sacrifice lag then too.
This winter I'm doing a 4" ets race kit and a set of kelford 272s with kiggly springs. I want to keep this hx35 and make around 450whp on pump gas but with me having problems with knock I don't see it happening unless I can up the boost into the high 20s ATLEAST with some good timing.
Car is tuned by me and my friend I'm not sure if I have a log saved or not I can check tomorrow.
