DSM 2G Brendon
- 0
- Nov 11, 2013
Logan,
Ohio
I just traded off my 93 Honda Civic hatch to jump over into the DSM world! My first car was a 2g Eclipse GSX, but at the time i didn't know what i had...but anyways unfortunately this has to be my first post.. But anyways i'll explain my issue the best that i can. The car idles fine and when i'm not building boost it drives fine if i stay out of boost i can run it up all the way through the gears with no issue. My issue is when I get into boost the car completely cuts out.. feels like i'm going to go through the windshield.. this doesn't really happen in first gear often , most of the time i can run it all the way up through first gear no issue, but once i hit second gear and i keep into boost which right now my gauge reads 10 pounds when i'm mashing it down but it creeps up to 12 pounds at high rpm. The cut out usually occurs at around 5-6k rpm. i notice it happens more once i past the 10 pounds threshold. I've read up alot and I think i am experiencing fuel cut. I don't know where to check first or what exactly this could be so any advice would be greatly appreciated. I am excited to make the jump back to the better side!
Thanks!
Thanks!
