- Thread starter
- #26
dsmaz
- 128
- 1
- Apr 17, 2012
Bullhead City,
Arizona
I dont have torque wrench but yes i did tighten that one part by the sensor down just a lil bit more than it was. i was careful to not over tighten. it did fix all the oil leaks but my car is still running the same so im going to pull the cam sensor off when i get home and see if there is any oil in there.Hopefully it fixes your leak, did you also check the torque on your cam caps while you had the valve cover off just to make sure everything was to spec?
