kamikazeredneck
- 74
- 3
- Apr 3, 2011
Los Alamos,
New_Mexico
Alright so I am in the process of building a 2.3 stroker and I am going to dable in the magical fuel e85. I'm building this car for hill climb and road course use so less boost with more timing and compression. I'm looking into running a divided t3 manifold and probably a turbo that has a efficiency range in the 30-40lb/min range but haven't decided which yet.
Now that the background is over I will get to the question. I'm looking to get the highest compression ratio on e85 as possible while running at most 30lbs of boost. I want the low end torque off the turbo with good turbo power. Now as some of you may know with road racing you don't want tons of boost hence why my max is going to be 30lbs. I have seen a lot of people running 10.5:1 comp ratio but could someone run around 11:1 or higher and still not have the probability of breaking parts. I understand with e85 you don't have knock but you still can break things. I have looked around in the search bar but cannot find things on this particular thought as most people run high boost with e85 but I'm looking to run higher timing and compression ratio. Any help would be great.
