NeedTalonNow
- 70
- 2
- Dec 13, 2012
Madison,
New_Hampshire
Anybody know what the highest WHP automatic DSM is? Is it someone on these forums?
did you finally pick you up one?
Jeff Bush
He wants an auto dsm if i remember correctly
What is he putting down? Member on here?
Ill show you a 650whp auto. Just give me 6 months. They can hold a TON of power with relatively low cost.
I cant wait to swap to awd auto. Fourcedfour box, IPT restalled converter,shift kit, clutches...... Im droolin.
Autos, im still researching and learning. Id like to see some 500+whp auto guys post up.
10.14 @ 131 stock weight. The most recent 10.08 was with some "slight" (2800lbs) weight reduction to try and keep from breaking. Mind you this car is driven on the street REGULARLY! Driven to and from the track constantly. Oh and on a stock 6 bolt.
Mr. Peepers resets dsm hx35 record! - YouTube
75 pound turbo? Whats that? Sounds heavy
What turbo specifically did you have in mind?
Seeiously though. "75lb turbo" means nothing, unless your talking anout lb/min of flow. Which you didn't say.....
An fp3586'will get you there.
I have a log from a dude at 42 psi on a fp3586 methanol and 93 octane with a perfect Ve map and was seeing 80lb a min....
You were saying what landspeed? Lol
As for op, I'll also be picking up a 3794 next season, not aure why you want the 86HTA compressor over the 67/94mm 3794
The 3786 is the 3586 compressor with the 37r turnine. Why not go for the big compressor also? Or are you concerned with spool?
Serious weight reduction? Stock converter is the most shocking part though. I thought those were nearly useless at the track. I'll be looking into a 75lb turbo so a re stall is a must.
Thats damn good time no matter what though. I think at 600whp at full weight i shouldnt have a tough time running in the 10s. Ive never ran at a track on anything ever but an auto is a whole lot easier to launch ovbiously.
Did this just turn from 0 to who has the biggest auto dick is a split second?
Who has the slowest modded auto on the site that doesnt run..Ohh thatd be me:grin:
