mitecl96
- 460
- 9
- Feb 20, 2012
McMinnville,
Tennessee
First off I am not sure which forum to put this in because it has to do with both. Sorry if this is the wrong place.
I am working on figuring out everything for megasquirt my 420a. I want to completely get rid of the stock ecu, but. I would like to keep things like cruise control and a/c because it is a daily driver and would like to keep it that way.
I have got a lot figured out how to keep everything. Right now I am working on the cruise control. I know on the 420a the cruise control is ran by the engine ECU but however, the 4g63 the cruise control is ran by it's own ecu. Could it be possible to use the 4g63 cruise control ecu in my car. I've looked at a diagram and only thing I see it hook up to is the TPS and the VSS. Are the signals the same on these sensors as the 420a sensors. If not, is it possible to use the 4g63 sensors on my car seeing that I am going to be running megasquirt.
Also does anyone have a auto-cruise control system ECU pin out for the 4g63?
Thanks.
Thanks.
