EVO9_Inside
- 75
- 0
- Aug 6, 2011
akron,
Ohio
So, 1991 gsx, stock compression forged motor, crower oversized valves, springs, retainers, stock cams, 20g turbo.
No egr, with blockoff, pcv deleted. Correctly ran vacuum lines to the WG, bov fpr. Safc tuned.
So when i start the car, it starts up fine, idles fine at 1700 warming up, but my afr is richer than it can read, tons of fuel coming out the exhaust, ect. If i press the throttle it misfires and stutters, making it undriveable, if you slowly apply throttle is revs almost normally.
Ive gone through the intake system twice. I cant find any leaks, passes the leak test, i have a feeling my unfamiliarity with obd1 is confusing me and keeping me from an easy diagnosis.
Anybody have an ideas?
