What Turbo is this? [Merged] Turbo ID Identification
Ah I see I see it has a precision power housing for the hotside, but wasn't sure what the turbine size was, Id like to id it so I can decide what its good for or what I want to do with it. Ill post the pic of the exhaust housing it came with too not sure what it is. I might just have to send it to you Justin so I can make some decisions. It does have some chips on the turbine itself. So it could be a garret?
Just wondering what Turbo is this exactly?
I was told a 16B never heard of a 16B I know it is a mhi from the serial.
Just not sure which one exactly. Does say tdo5h on the housing.
I currently have a 14B that will be in need of a rebuild soon.
I am planning my rebuild That will start in February.
Bigger Turbo but not by much is one of the upgrades I want.
MHI 20G.
Compressor doesn't appear to have rubbed the cover from up/down play...if it's a fair amount of in/out play you're speaking of, I'd pass on repairing it for sure as there's a good possibility the only usable parts will be the center housing and turbine housing.
MHI 20G.
Roger that.
There is both a great deal of in and out and up and down. Its a cats hair from touching the housing.
Appreciate your time.
Whats a better turbo from these two?
a S16g or a 14b?
It would be going on a 1g auto.
That would depend on the boost level you're looking to run. The wheels themselves are nearly the same size so either turbo would spool almost the same; the Small 16G being more-efficient at higher boost levels.
I'd recommend the Small 16G with a 14B's 6cm turbine housing for quick-spool on the auto. ;)
Thanks Justin, That Small 16g is on it way to you for the rebuild, thanks.
Hey guys, I bought this turbo off Craig's list back in 09. This turbo has no markings on it, and the guy I bought it from didn't know much about it either. He thought it was a sbr gt50? The inlet is 2 1/2" Any help would great. Thanks
Another picture
Another
