Sooo i keep popping fuel lines...
The actual fuel line from the rail to the regulator, it exploded last night when i was aoing home. I punched it getting onto the interstate and it literaly popped. Made a "pop...sssssss" sound and there was fuel everywhere on the line.
Is your mod list in your profile up-to-date? I don't see an AFPR listed. If you do have one, maybe check to make sure it's not getting clogged somehow. They're pretty easy to take apart.
What kind of line are you using? Are you using a high pressure fuel line? Or ideally you should be using an -an line going from the rail to the afpr.
My tuner made them. So turns out the pop noise was a coupler but I still busted the line around 4-5 inches from the regulator. I'm on line #3 so lets see how long this one holds up.
I'd like to see a picture of this mess so we can all be clear on what's really there.
