DSM_Newblet
- 76
- 0
- May 17, 2012
phoenix,
Arizona
Hey! Just picked up a 91 Vr4 about a month ago with 93k original for a steal so decided I would build it, go figure. The plan is 400awhp streetable and even, fingers crossed, daily driveable. Well here is a list of the mods, after much research, I was thinking to reach my goal. (excluding maintenance, tranny, tcase, etc. because I have already got those taken care of.) All input, advice, other options, experiences and all around comments are appriciated.
Also keep in mind I will be running e85 as I live right down the street from the pump and love the stuff!
List may be a little out of order, have spelling errors and maybeeven missing some stuff so I appologize in advance, again feel free to comment on anything.
Cams - Crower 272/272
Springs/retainers - Manley single spring and titanium retainers
Fuel pump - rewired walbro 255
AFPR - already have an aftermarket afpr on there not sure what brand, came with the car, but might keep it as it looks to be working properly)
Injectors - FIC blue max low z 1350cc (what do you guys think for e85 on the hx35?)
Ecu management - ECULink v3 full or lite(not sure if running SD or not, suggestions?) with the EPROM
Turbo - Hx35 8 blade with BEP housing (not sure how many psi I will run just yet for my goal, maybe 23-26?)
Exhaust mani - 2g ported
02 housing - MAP 38mm external wastegate recirc to exhaust ( Is this a good size or bigger?)
FMIC - ETS 10inch FMIC kit
BOV - TiAL 50mm Q recirc BOV
MBC - Voodoo MBC
Gauges - Not sure on brand yet, but wideband a/f and boost
Exhaust - No idea need to do more research of what will fit but definately 3inch no CAT
So that's about it for now, somethings may be too much for the goal or not enough so just let me know. I will continue to do more research and add to the list while also considering all input.
THANKS GUYS!
MBC - Voodoo MBC
THANKS GUYS!
