Rock2610d
- 255
- 4
- Jan 22, 2013
Cheyenne,
Wyoming
Searched and searched but could not find all the part numbers I need for a drive-shaft refurbish.
This is what I have so far from searches, I assume these are good for a Talon?
2G AWD
MR165048 Front Center Bearing...does this come with rubber?
MB837577 Rear Center Bearing...does this come with rubber?
MR470072 Transfer Case Recall Kit with transfer case seal
NEED:
U-joint part numbers, each...not an entire kit as I have a u- joint in Yoke kit.
And any other parts that I do not know I need too, for a full Refurbishment.
Note I have the transfer case fluid so I do not need that, or grease.
FAQ shows procedure but does not list part numbers and is not 2G I do not believe.
Thanks
2G AWD
NEED:
Thanks
