hadouken97gsx
- 0
- Feb 19, 2013
Granite Falls,
Washington
I drove my car home one night and let it idle in the garage for a few minutes, boost gauge read roughly -19hg, even though I didn't drive hard whatsoever and in the morning when I started it I noticed my boost gauge was reading -12hg and has a little bit of a lumpy idle. Now I have searched and searched and found the biggest culprit was a BL. I did a BLT and found my intake manifold and my injectors were leaking a tiny bit so I replaced my IM gasket and injector seals and did a BLT which showed no leaks. Replaced my plugs, swapped in a known good EGR, scanned with obd2 and I ran bad rear 02 (which I have known) and p1105 fuel pressure solenoid. I bypassed the fps and still the same thing is happening. I am desperate guys as this is my DD and I had just got her running again 5 months ago. Any help is much appreciated and I am up to try anything to help it.
