cabot2g
- 757
- 0
- Feb 13, 2012
Cabot,
Arkansas
Didn't get the chemist job, I have one more chance to get on with entergy.
Anybody have a 2g roller I can pick parts off of? Need a few things.
What do you need?
Picked up ECULink (DSMlink) V.3 Full with Socketed ECU for $350
I need blinker switch (headlight switch) please.
Tan trunk carpet, right tan tail light access cover, right door interior mirror piece (triangle shaped), and probably some other things
You need the whole multifunction switch. Il see what I can do.
All grey black here buddy. You could probably dye it.
In the middle of my manifold swap. Took two hours to get the stock unit off!! Bottom bolts are hard to get to!! So while the manifold is out, I plan on replacing knock sensor, dropping the battery lower, removing EGR and EVAP. Anyway I have a few questions.
1 - I am missing one rubber injector rail seat. Anybody have one?
2 - I have a 98 so I think the EVAP can is in the front bumper? Is it?
3 - Two lines running to the EVAP are under the battery. Can I disconnect those? Do I need to cap the line coming from the gas tank? I guess it removes vapor?
I may have a switch, ill look around for it.
Frustration!!!
I completed the battery drop. Autozone 26R battery is required. I tapped the EGR hole and plugged it with a 1/8 pipe bung. But I cant install the JMF coil bracket cause I cant get the AC compressor off! I have three bolts loose but I cannot get to the lower driver side compressor bolt. I tried swivels, extensions, rachets, renches, everthing I got. I can put my hand on it, but no way to fit a tool in there because of the frame. Am I missing something here??
The AC lines are still attached. I didnt want to discharge into the air. Will removing the lines give me more room?
Frustration!!!
