sleeperhemi
- 82
- 1
- Sep 22, 2012
White Plains,
Maryland
Hey folks...couple quick questions. Going to have a new timing belt and water pump installed soon. I was considering changing the cam gears out for just cosmetics. OEM cams are in the motor and I have seen a few sets of adjustable gears that I like. Again......just for looks, will I run into any problems having these installed with a GATES timing belt? I'm sure that the teeth on the new gears will match up to the originals but I just want to be sure. Also, is this a big project....changing the gears that is or is it a quick bolt on deal? Thanks!
1999 Eclipse GS
420A
1999 Eclipse GS
420A
