Sullbren17
- 175
- 0
- Nov 29, 2012
Chadron,
Nebraska
I have a 420a in my 96 eclipse I have a talon tsi completley stripped excepts the motor and harness mounts etc I did some lookin around and I don't see a thread on HOW to do the swap. I know it takes skill and such and a lot of fabrication. But so far the problems I run into when I try to plot this out is where exactly to put the mounts without any issue. So my thought exactly was to measure the mounts on the talon and cut and weld to the eclipse I thoughtthat would take care of that but I thought about the radiatorand the shift linkage is differentand the cross member and exaugst. Anyone have done this before would he great to have a real tech article on how to do this
I know you need...
4g63 motor and transmission
Cross member and mounts
Ecu and wireing harness
And axels
I know if you have the mounts wrong it will throw out the transmission
And what tools you need for the job and any article to show this will make the 4g63 swap more realisic.
I know you need...
And axels
