Zufelt
- 533
- 9
- Oct 15, 2012
Lemoore,
California
Alright, I just got my wideband in the mail and figured it would be straight forward.. Unfortunately for me it's not. I understand that the wires are
Red - Ignition Wire 12v
White - Is to dim the light, which I'll be grounding instead
Black- Ground wire
Yellow- Analog out 1
Brown- Analog out 2
I just can't figure out where in the ECU pins can I put the yellow and brown? I don't have DSMlink, but do plan on using it within the next couple months. So would the yellow still go at the 76 pin? I am creating a new bung for the sensor, and would like to use it's datalog features.
Unfortunately the information isn't on Vfaq and is somewhat confusing.. any help would be greatly appreciated
Visual Frequently Answered Questions - Home Page
mtxinstall [ECMTuning - wiki]
This site is helpful, but not sure if it would be the same being that I don't have DSMlink yet. Also, instead of tapping into the pin, can I just tap into the wire before the harness that goes to that specific pin? Perhaps that's what everyone means and I'm just taking it to literal. I also don't want to tap into any other sensors such as the back because it's needed for emission purposes. Thanks for any info, I know it should be an easy install but I have a habit for overthinking things..
EDIT: Since I don't have anything to LOG with, and I don't need to simulate a narrowband for the ECU would I just hook up the sensor and it would read my Air/Fuel while I wait to buy DSMlink?
Black- Ground wire
Brown- Analog out 2
