Blak Pearl
- 63
- 0
- Dec 6, 2007
San Antonio,
Texas
Here's a quick run down. I have a 98 gst that I converted awd and then recently just finished installing a ford 8.8 keeping it awd. I bought conversion fittings to mate my exsiting brake lines to the ford calipers and made ss lines. I also have a cnc staging brake that installed. I bled the system numerous times and the pedal still has a spongy feeling.
Things I have replaced are:
-2g brake master cylinder
-3g brake master cylinder
-new proportion valve
I have no leaks, calipers are good so i have no idea what else to try. My concern is that, since the ford calipers are bigger maybe the master is having a hard time getting fluid in the rear calipers, therefore causing the pedal to have the spongy feeling. When I drive the car and push the brake pedal, the pedal travels almost to the floor before it starts to stop.
any help would be great, thanks
