Aproductions
- 2,124
- 50
- Aug 11, 2009
Allentown,
Pennsylvania
Doubt a simple bore will get that out, good chance it goes thu the wall into the water jacket. But a sleeve installed will fix it.
That 100% needs a sleeve.
I'm sorry, but what is a sleeve?
A bore insert. Some diesal engines are made with just sleeves. The cylinder isn't part of the block.
Really?! I learn something new every single day.
So is it just pressed in? I'm assuming the sleeve is made of steel, and being pressed to aluminum I can't see any other way.. From my experience, steel and aluminum together causes a detrimental reaction how does that work? Also, I know steel and aluminum hear up at different rates making the block and/or sleeve susceptible to cracking.. I'm just not sure how they overcome these issues, I can't see any thing other than steel being used as the sleeves material or am I over thinking it?
