lowcashleblanc
- 43
- 0
- Apr 4, 2013
Atlanta,
Georgia
Post:
1. Intro
14. Tear down and prep
15. Small update
Work has finally began on #1027. The Photos below were taken the day she became mine. I traded a Garret GT2860rs with Tial goodies, Miata 6 speed trans and a Mishimoto radiator for her. Since I have gotten her I have picked up a replacement transmission for her and a V3 ECMLink with more to come.
Build Goals:
- 300 to 325 HP respectively
- Daily driver
- Simply clean build
- Personalization
- Fixing short cut mods that were done by PO's
- Paint (original color is belize green but Im kinda diggin the sea foam green) strip and re spray the sea foam green.
Parts to buy list: (extremepsi.com)
NGK Premium Wire Set
EVO III O2 Housing
OEM O2 Housing Gasket EVO III
Gasket EVO III
OEM Rear Main Seal
OEM Rear Main Gasket
OEM Water Pump Assembly
Redline Shockproof Gear Oil x2
OEM Oil Filter
Extreme PSI Timing Belt Kit
OEM Oil Pump Front Case
OEM Mitsubishi Front Case to Block Bolts
OEM Oil Filter Bracket Gasket
OEM Oil Pump Drive Gear (Straight)
OEM Oil Pump Driven Gear (Straight)
OEM Oil Pump Front Cover Gasket
OEM Mitsubishi Engine Oil Pump Sprocket
Pics from this weekends tear down in prep for installing the replacement transmission. Lots of labeling and taking photos to reference when I get to the point of putting everything back together.
Hand scrubbing this sucker and flushing it out in prep for the HD shockproof that will be going in it after its install
V3 ECMLink
Take off parts
1. Intro
15. Small update
Build Goals:
- Daily driver
- Personalization
EVO III O2 Housing
Gasket EVO III
OEM Rear Main Seal
OEM Oil Filter
V3 ECMLink
Take off parts
