goldeninja20
- 589
- 3
- Dec 5, 2010
Norton,
Massachusetts
I am having major lean problems in boost, but according to evoscan my injector duty cycle is only reaching 60% at 4500 rpm. My AFR is 12.5 acording to my innovate MTX-L at only 15 psi on a small 16g. My target AFR in ecuflash is 11. I have tried to up the fuel pressure, only resulting in a rich idle. I have tried to increase the injector latencies, also resulting in a rich idle. I had the same problem with my stock 450cc injectors. I have a new fuel lab fuel filter, fuel lab FPR, and walbro 255 pump. I did not do a rewire, might this be my issue, it is my only thought?
