Will this transfer case work?
eclitz88
59
Jul 2, 2012
Dixon, Illinois
Hello DSMtuners
I just bought a 95 gsx 5 speed and the tcase is shot as for the output shaft is too.
I also have a spare trans and tranfer case for a 5 SPEED first gen gsx.
My question is, will the output shaft and Transfer case for the 1st gen work in my 2nd gen? Tabks for all replys!
Hello DSMtuners
You can use a 91-96 transfer case with a 95 trans , you cant use a 90 or 97-99 transfer case.
I have a 90 awd turbo trans that I want to take the outputsaft out and put it in my 95 trans. and use the transfer case. It's all 22 spline. will it work? or will the ratio be all messed up and cause more problems? thanks for your reply
Alright sweet. This swap will save me a bunch of money. But I need to be a 100% positive that it will work since my trans has just been rebuilt. Is there any disadvantages to doing this swap?
Thanks agian.!
