syndr0me
- 147
- 27
- Oct 19, 2011
Pincourt,
QC_Canada
Hey guys,
95 talon
6 bolt block
should be less then 100K on the engine.(accoridng to previous owner.)
So before I put my car into storage, it was A1 and running like a god @ 25psi, 16g.
Now, it's giving me a hard time. I set my injectors for 650cc, invert CAS and set idle in DSMLink. (Just like it was)
However the car, when I start picking past 10psi of boost, the boost seems to increase but the car slows down and has this braking type of effect. I hold this for an extra 500rpm just to be able to get clear cut data in the logger and let off right away off course to not induce any damage!
Logger also starts showing around 4-5deg of knock at that point and pulls the timing.
I just put brand new plugs in, BPR7ES and a half a tank of 91 Oct.
I'm currently doing a compression test,
145 - all good
150 - all good
150- all good
148 - all good
Battery also came from the junkyard, guy said it worked, it does but im wondering if it's a weak one that causing wonky electrical instability.
I fuarkinngg beautiful outside and just plated the car, help me!
thanks!
95 talon
6 bolt block
145 - all good
150 - all good
150- all good
148 - all good
thanks!
