nicknorth11
- 663
- 7
- Feb 9, 2005
Grand Blanc,
Michigan
I was removing my transmission and in the process ended up cracking this ear on the block. The crack goes all the way through to the threads. I think this bolt goes through the transfer case and then the block, but I'm not positive about that. Also, while backing out the bolt, The threads stripped. I have two questions about this.
1) Is it absolutely necessary to fix this, or will I be safe without it? (Please don't respond with, "It there for a reason." We all know there is plenty of stuff on our cars that we can live without.)
2) If I must fix it, should I have it welded before or after I try to tap the threads?
