Archer Fabrications
- 9,734
- 697
- May 9, 2011
Scottsdale,
Arizona
is that a S&W roll cage? i like how it doesnt have to go through the dash.. or does it. i did notice some kind of bar across your dash. that is on my list as well.
Honestly this is not even the half of it! I had a more complete thread on dsmpurity.com the owner of the site sold everything and I lost all of my build. I saved most of it but this is only a fraction.
Did you consider upgrading to a 3G brake booster, master cylinder and fluid reservoir? It would be a breeze at this stage of your build and since you have everything out of the way to run the brake lines. Great build BTW.
Its just insane how much work you've done just in this small fraction. I could only imagine the entire project laid out in this thread. You even painted it yourself!! Wish I had the skills and resources to attempt this!!
who did you order from ?So still slowly working on it.
I ordered plugs, wires, relay/fuse box, ETC... to get the harness wired up.
Started with the switch panel. Switches are Main, start, alternator, fan, fuel, lights. They each have their own fuse and relay now. Main switch triggers the Ignition and ecu/mpi. It also powers the other switches which trigger their own relay.
Should be fire / melting proof now compared to what I did have!
Waytekwire.com
