91gsexx
- 0
- Apr 7, 2013
Statesville,
North_Carolina
Wanting to make 400 on pump have 750cc injectors 255 what turbo to go with want to try to stay stock manifold what turbo should I run
Although it deffinately can be done with a 20g.
I seriously doubt your going to make 400whp on a 20g on straight pump gas. Not to come in here and be a thorn in your side, but unless you have a great setup with a very good tune, 400whp on pump with a bolt on 20g more then likely isn't gonna happen. It's not as easy as just simply bolting a couple parts on the car, making a few changes in DSMLink and BAM 400hp. I just don't want to you see a thread 2 months from now saying I went to the dyno and only made 320whp what's going on? You know?
