WOTDSM
- 167
- 0
- Dec 3, 2006
Detroit,
Michigan
Hey guys. I'm in the process of doing valve seal job on my 1G. Got everything back together and I was starting to install the intake cam and heard a loud snap.
Busted the intake cam right in half. Luckily my buddy has a spare set of cams from his 1G. We heard a small pop when we were doing the exhaust cam too but there is no sign of a fracture, we're using his exhaust cam anyways just in case.
Should I install the cams without rockers in them, at least the ones that are being pushed open? Or should I keep the rockers in and just do a couple turns per cap till I hit 15 ft.lbs.? Also, should I be worried about using used cams in my motor? I've heard that cams are somewhat mated to the motor that they came in from the factory, since they're scored on the cap surfaces.
Thanks for the help guys.
