MrNeedles
- 79
- 0
- Jan 17, 2009
Chicago,
Illinois
Please help me out here guys.
I just finished my auto 2g. When I turn the key to the accessory position I can here the fuel pump kick on, along with a loud clicking from some relays located on on the passenger side. I think they are the fuel pump relays. It will do this 3 times and then stop. I try to start the car but it wont even crank. I notice when I try to crank my car, the tach jumps slightly to 1000 and the fuel pump kicks on while i'm turning the key. Maybe grounding issue?
I relocated the battery to the trunk, but other than that everything is the same. To relocate the battery, I ran 0 gauge from the starter> harness> 150a breaker> battery. The negative it grounded to the rear strut tower. My dash lights work and so do all of my accessories.
I also don't know where this plug into:
This is how I grounded these:
This is what is clicking:
Here is the video:
[ame=http://youtu.be/VJ0aKny4alw]DSM relay clicking - YouTube[/ame]
You can here the clicking clearly but the fuel pump is also kicking on in the same intervals as the clicking.
any advice is appreciated.
Here is the video:
