goldeninja20
- 589
- 3
- Dec 5, 2010
Norton,
Massachusetts
I have just set up my blackbox ecu in my 1997 eclipse. It is ready to be tuned. Today at the junkyard i came across a 3 bar GM MAP sensor. On ecuflash under "Version and Extras Info", I see "Speed Density". It has a "N" for which i believe means no. Does this mean my version does not accept speed density. Also Do i wire MAP into MDP sensor plug or do I wire it from the wires at the maf. I am a little confused on the set up if someone could explain it a little more in depth. I cannot find much info on this with the 98/99 ecus, I find more with evo ecus but im not sure if it is the same.
Also have a question about wiring. Do you need to wire ground and positive or just run pin to ecu?
