- Thread starter
- #3,376
Phil1320
20+ Year Contributor
- 2,256
- 39
- Dec 9, 2002
Rocky Hill,
Connecticut
Oh yeah, I forgot about that!
I was running 52psi base pressure on the stock 450's with a rewired Walbro and C16. I remember when inj DC transitioned over 100% the car would give out a little cough/sputter then run cleanly above 100% DC.
Phil, I can look up the timing in the chip I made for you. IIRC I left the timing stock up to 6k rpm where the stock map peaks, then I added one degree for every 500 rpm. So 6k was 24*, 6500 was 25*, 7k was 26*. I think you said you were using the CAS to fine tune it?
Yep, that sounds right. Yeah, I had base timing set at 10° BTDC.
