triston2469
- 231
- 0
- Sep 15, 2012
Yukon,
Oklahoma
Well per usual with my car, I fix one thing and something else arrises. i have had an issue with my cruise control not working well as I was trying to trace a wire and see where it went (which was pointless due to my computer being bad) I noticed my clutch pedal wasnt all the way out. I pulled on it a little bit to see if it would move and found out that my pedal would move.
well my first thought was clutch master cylinder was bad. Well so i watched everything as i moved the pedal in and out with my hand and found out that my clutch pedal has alot of play in it before it actually starts to engange the clutch master assembly.
So now i get to replace my clutch pedal assembly luckily Shepard Transmissions makes an assembly with brass bushings and is welded so looks my weekend project is gonna be to replace that. I love my car. haha
