xxShaneOmac
- 425
- 0
- Jan 2, 2007
Everett,
Washington
I have a 6" section of 3/4ths inner diameter tubing that I want to make air tight.
My idea is to seal this section and then fill it with air that can be regulated by a valve and used elsewhere.
This is my question. What would be the best choice to get the most air? A rubber tube with the ends sealed filling the area, or a tubular air hose that fit inside and filled the same area.
Is one better than the next or would they both equal the same as the limiting factor is the 3/4ths ID tube in the 1st place?
Thanks.
Thanks.
