Hx35 10.3
It was nice seeing you there, 95talongirl! Really unexpected, didn't realize you were so close.
Stock converter, no nitrous. Stock flexplate still, too :p
The manifold I made specifically for this turbo.
10.1 pass:
<iframe width="560" height="315" src="http://www.youtube.com/embed/zfZNFcx7skc?rel=0" frameborder="0" allowfullscreen></iframe>
10.2@132 you can see I didn't let off the brake all the way and it hit the two step as I was rolling out
<iframe width="560" height="315" src="http://www.youtube.com/embed/08Y7PQy-gSM?rel=0" frameborder="0" allowfullscreen></iframe>
And breaking the tcase:
<iframe width="560" height="315" src="http://www.youtube.com/embed/y70qZyeWGCQ" frameborder="0" allowfullscreen></iframe>
Congrats again man! A awesome way to end the season! Still can't believe the day went well for both of us even with all the carnage! haha
As for the output shaft in the yoke his and mine pulled right out. I just put a vise grip on it. I did break one before and it was a pita to get out. I just put a vise grip on the output shaft right up against the yoke and sorta pryed it out with the vise grip.
Congrats on the pass. I would like to know what solution you come up with for the springs. I have been interested in dealing with the weight transfer (squatting issue) as well. I have yet to find a spring to allow good rates without dropping the car. :hmm: Of course coilovers and hypercoil springs will give you a ton of options but let me know what you come up with. :thumb:
As for changing the title, click edit on your first post and then hit go advance. It should be your 2nd line and you can alter the title. Some sections have time limits on editing so if you do not see the edit button, that is why.
Congrats Again,
Robert
Thanks Robert!
I have some evo8 struts and springs I will play around with and maybe put some DSM lowering springs on them, haven't been too focused on that aspect yet though. Power came first :)
Maaaaaaaaaaaaaaaaybe one day you'll sink some "real" money into these projects instead of budget building them! Haha but congrats again Matt!! I should have came to the track instead of watching foozeball.
Kenny better get his ass in gear before you pass him in the 9's! ;)
This is so inspiring! Congratulations on the run! Just saw this actually have an hx35 in the mail as we speak going on my 1g auto. I just have to figure out how the F you launch so hard. Mine is such a dogg...
Thank you :D
For my car, it was all in timing retard at the line and making sure the two step turns off immediately when I let off the brake. Allows me to leave at 3250 rpm and near 20psi.
Over the winter I'll set up the car so boost is limited at the line(instead of rpm) so I can finely adjust what psi the car leaves at depending on my tires/track conditions/drivetrain strength :p. Imagine a wastegate on the upper IC pipe that is controlled by a boost controller, tired into a solenoid controlled by the brake switch. Dial in the boost off the line when the brake is pressed through a controlled boost leak, immediately(or even have a tunable close rate) slam the boost leak shut to let boost quickly ramp to whatever I'm running. Timing will still be retarded when the brake is pressed so rpm doesn't have to get very high to reach the desired launch psi.
I won't end up using an external wastegate but it will function the same.
This way I can get away from a fuel cut launch limiter which still sucks in the end for consistency(boost still bounces around) and tune ability for an auto. 250 rpm increments are a big jump when you're only leaving in the 3000rpm range. Hopefully get consistent 1.5's on street tires and into the 1.3's on radials with less drivetrain issues. Excited to find out!
Keep us posted on how that works out for you.
I am planning on using the studder box (vss based) to control launch rpm. So far it is working, except I am pulling through the brakes. (4 pot gto calipers & hawk pads)
I also think it might be possible to wire the base timing to the brake switch for torque control when launching.
I'm currently using base timing at launch, and have it set at 0 BTDC and adjusted my normal timing map to compensate(+5, just have to remember that it's not face value). VSS launch control didn't work well for me at all, it tends to tap the limiter once or twice as you roll out.
Awesome progress! I'm almost done getting mine back together and I'm definitely going to wire up the NLTS and base timing to the brake pedal after watching you launch.
So how did you wire up it up to watch for the brake instead of clutch switch? Link?
