Eagle96TalonTSi
- 292
- 0
- Oct 9, 2012
Crowley,
Texas
In high RPM, when I bump the gas I can still hear the motor shift around. I replaced the front, and front left motor mounts when I did the timing/water pump last weekend.
Could this mean that it is one of the other two motor mounts? Could it possibly be something else?
Also, I am seeking advice on what path I should take on the maintenance my car needs.
Problems: Car is lowered 2" on stock struts (Struts are leaking and rough ride)
Clutch is really soft. Still shifts fine, but needs to be replaced.
Still have the motor moving around in the engine bay in high RPMs or sudden stops
What should I do first? The car sits so low that my o2 sensor was pulled out of the bottom of the car and I had to spend 100$ to replace it, and I dont want that to happen again. I am barely driving the car, as I have a DD but I want to DD the talon asap. What should I take care of first? Struts or clutch? And whats up with the motor mounts?
