H@xtGSX
- 1,093
- 9
- Aug 9, 2011
Carlsbad,
New_Mexico
I have an extra exhaust manifold that I have been experimenting on and I have decided to acid port it. I have done the standard lip porting on the manifold that is on my engine now, but I am convinced that the 2g stock exhaust manifold can be ported out to FP casting size runners, if only you could get a porting tool INSIDE the runners... Nothing I have used worked very well, die grinder wise. I also tried a homemade "extrude honing" mix I whipped up with silca sand, clay, and old motor oil. It was effective, but it would have to be automated. It'd take many hours to get much done. I learned something from the older super stock racers though. Acid porting used to be the best way to port out intakes and exhausts because it'd get to places tools couldn't. Plus, it'd leave a stock looking cast like appearance, so you could cheat the super stock class rules some.
I'll post some pictures when I get started. Anyone have any prior experience with this? I'd love to get a tip or two, just so I'm not totally guessing.
