spadepro22
- 1,206
- 10
- Mar 13, 2008
Seneca,
South_Carolina
Let me start off by saying I've researched, but still have some questions that I'm not sure about. 1st off I've read that bigger compressor wheels with a smaller turbine will cause compressor surge. I have a 20g compressor wheel with 16g turbine in a down firing housing. Could I still get compressor surge?
Next, I installed a new NGR bov and its fluttering under low boost but fine in the higher range. I've read that for the valve to hold high boost it might cause some surge/flutter down low. Some say that its fine and others say you shouldn't have any. Is there any clarification here? I haven't adjusted my bov softer from the factory setting yet, because I don't want it to leak. I'm running 18psi so if I did the single spring mod, do you think it would hold the 18-20 psi, or should I just adjust it softer to see if the flutter/surge stops without leaking?
Any videos with flutter and surge would also help being I can't seem to tell them apart at this point
